Results 1 to 6 of 6
Thread: Squaring Colombo Z axis
    MGM Television, Vancouver British Columbia
    Default Squaring Colombo Z axis
    I just finished flattening the table of my new prt, it is showing signs of the z axis not quite being plumb as there is some "stair stepping" evident in the flattened table surface.
    The assembly manual is very light on specifics on how to adjust the squareness the z axis of the colombo spindle...any suggestions?
    Fort Worth TX
    Boyd,
    See if this thread helps:
    http://www.talkshopbot.com/forum/mes...tml?1033502488
    Ron
    Oct 2001
    Ron, have you noticed that some of the good old threads are already buried in the archives - maybe we should take the hint and go into retirement.
    A dusty old thread that may help Boyd:
    http://www.talkshopbot.com/forum/messages/7/1291.html
    Thanks for the reply guys, but I think I must be missing something obvious because I can't see any provision for adjusting the plumb of the spindle mount short of spacing the carrier with washers which seems a little archaic to me, besides which I only need to adjust it 1/64" or less.
    If you could see the way the new Colombos are mounted, there does not seem (to me) to be any way to adjust it.
    Boyd,
    it may be archaic but it works!. That's pretty much a standard approach in the machine world. You can buy a pack of assorted "U" shaped plastic or metal shims from most industrial supplies.
    Eric
    Oct 2000
    Atlanta GA
    a deck of playing cards works wonders
  1. Squaring z-axis on Buddy
    By pyrodenis in forum ShopBot Buddy
    Last Post: 07-03-2014, 09:38 PM
  2. Z axis squaring help?
    By JimFabLabFulton in forum PRS Assembly
    Last Post: 12-05-2013, 10:21 AM
  3. Looking for tips for squaring the X-Y Axis
    By ampd in forum ShopBot Buddy
    Last Post: 06-03-2009, 10:04 AM
  4. Installing & squaring the Z axis..
    By geneb in forum Archives2007
    Last Post: 01-12-2007, 10:00 AM
  5. Squaring the Y car to the X axis
    By sagreen83 in forum Archives2005
    Last Post: 06-12-2005, 06:47 AM
